Resolume 7.13.2 Released | Hotfixes Are Now Free!
From now on all micro releases (major.minor.micro) are backdated to the previous major or minor release. So if your license was eligible for version 7.13.0 you're also eligible for version 7.13.2 even if your license has expired before version 7.13.2 is released. We think this is only fair and it keeps everyone on the most stable version as possible. Normally micro releases contain only a few bug fixes, but to celebrate this license change we did sneak in a tiny little new feature in Arena and one in Wire. If you're the first to find it then post a screenshot on social media with hashtag #resolume you'll win a grand prize! :-)
Minimum OS Requirements
Arena, Avenue, Alley and Wire version 7.13.2 now requires at least Windows 8.1 and macOS 10.14 Mojave.
What was New in 7.13 Again?
A LOT! Checkout the 7.13 release notes and the video below.
Avenue & Arena Fix List
#16974 NDI can flash to old resolution and then breaks after a source size change
#18017 886x1916 NDI source doesn't play in Resolume
#17060 Crash alt + dragging monitor from main window to create duplicate in new window
#17904 Crash triggering clip to Free layer with Clip time panel enabled, and no free layers available
#17987 Crash replacing clip with another through the API
#18048 Avenue crash on shutdown
#17629 Update check still can happen after deactivating it in preferences
#17817 Creating lots of slices causes crash
#17839 BPM field accepts value outside 20-500 on second try
#17977 Offline registration no worky
#18020 Spinner should change value if you click slowly too
#18047 Not all NDI PTZ parameters are animatable
#18046 NDI PTZ Auto Focus parameter easily overlaps Focus parameter
#18158 Resolume can hang trying to play clip with missing track with Pioneer and Denon sync
Wire Fix List
#17811 Crash saving patch with PDF added as license
#17979 Crash replacing nodes from library
#16319 Watermark Wire MIDI & OSC outputs
#17715 Auto index Input node names if one with same name already exists
#17841 Moving slice input in dashboard, or adding a new input reverts Slice selection to none
#17919 Color selector in the node menu is misaligned
#17983 Do not replace Comment nodes
Download
Select "Check for Updates.." in the Avenue or Arena menu and it will self-update, including Wire. Or checkout the downloads page.
Re: Resolume 7.13.2 Released | Hotfixes Are Now Free!
hmmm....it's a shame that nobody said thank you before for this awesome move. This is unconventional and very refreshing in a subscription driven world. So thank you very much.
What about the sneaky feature?.... had it been found already? :)
Best wishes
vjkatza
Post by vjkatza »
Sneaks I posted on Instagram a few days ago: :roll:
https://www.instagram.com/p/CjGZ_G5NBvi ... _copy_link
vjkatza wrote: Tue Oct 04, 2022 14:15 Sneaks I posted on Instagram a few days ago: :roll:
Oh mann....nice one :D ...I was so sure it must have something to do with audio..... but I was so blind.
Congratulation Katza :) - What was the "Grand"- price?
Best wishes
vjkatza
Post by vjkatza »
cosmowe wrote: Tue Oct 04, 2022 18:41
Best wishes
Well, I don't know if I'm the winner though I didn't find any #resolume posts over insta / twitter.
But it doesn't matter as to me (and to all of us I guess) The resolume team & software is already a grand prize.
true...true!
