install hiccup with AE
drxian
Post by drxian »
hi guys supper appreciate the opportunity to install the latest version even though my support stopped one version before! however just FYI if you are running adobe products while you install via check for updates inside resolume (and maybe during a manual install as well). RESOLUME will install but adobe support updates won't and in fact will leave your AE products crashing when you next launch them because of incomple or partial resolume install of adobe related things..
workaround hopefully download the full installer and do it manually and ensure you have quit your adobe products in my case AE.
Re: install hiccup with AE
Yes, you need to exit Adobe apps, so the installer can update the plugins.
