Resolume Syphon output into Synesthesia
corunography
Post by corunography »
Hello! Does anyone have experience using Syphon to feed Synesthesia? I am trying to output 2 different syphons streams from Advanced Output and switch between them in Synesthesia, but they are all showing up as the same name so they won't trigger. is there a way to change the output name of a Syphon from Resolume via Advanced output?
Also, I'm assuming Syphon is better on a processor than NDI?
Thanks so much!
corunography
Re: Resolume Syphon output into Synesthesia
Update: it’s a glitch with Synesthesia. They say it will be addressed in an update soon. In the meantime I wonder if there is a way to rename a syphon after it leaves resolume. Hrm!
Resolume syphon streams get the name of the Screen.
Renaming the Screen could help.
rename screen.gif (37.04 KiB) Viewed 2234 times
