FX Master fader
Acidvideo
FX Master fader
Post by Acidvideo »
What i sometimes really miss is a master fader for all the effects for instance on compostion level
Re: FX Master fader
You can build this out in Wire when building out custom FX stacks
Acidvideo
Re: FX Master fader
Post by Acidvideo »
i don't want to buy Wire
Re: FX Master fader
How about mapping your midi fader to all the effect opacities you want to control https://resolume.com/support/en/midi-shortcuts ?
Or assign them to the Composition dashboard: https://resolume.com/support/en/dashboard
Acidvideo
Re: FX Master fader
Post by Acidvideo »
You're right, that should work
