Live audio and Resolume show M1 mac.
borez
Post by borez »
Any of you guys tried running an audio ( say Ableton ) and Resolume show at the same time from one M1 macbook pro.
Be really interested to know if it can hold the frame rate.
Re: Live audio and Resolume show M1 mac.
If you're not using hundreds of Audio effects in Ableton, then the audio processing is really not that significant besides the video load Resolume will do.
Simple Resolume and Ableton shows worked for me on on my old macbooks too.
