Grid Cloner
ether
Grid Cloner
Post by ether »
Hi
Am slowly getting into the cloners - they are very cool and i LOVE the Delay function - what would be amazing (as a Cinema4D user) would be if there was some type of 'Grid' Cloner, or even a Linear Cloner in X or Y directions - and also to be able to position the Center in X and Y directions would be fantastic.
Thanks - Keep up the good work devs!!
MarkyMark
Re: Grid Cloner
Post by MarkyMark »
Working on it :D
Re: Grid Cloner
Grid Cloner:
Code: Select all
--begin-wire-patch--
2489.3oc6ak0aaijD9uhgdVM2tq9NuIIRMX.1cmAyrOrKxZrfVhxVHxTFRTSxrA9+9TcSpKqlTT9HwJ1NvzgRUeU0WW0W0Gesyn444YiJlNOeYmO7wu1Yxh42h+Gc2NyWUb2pBZmK61oXN9QR2eI2NMuyk22cifptcVjsb9rUtpXirXwmlWV5iJaU8l9k8jkQW2C1HHCBVqLV8Rx1WxtctKsnHaw1FmwCWmvg0IObcxCpo7RtmfvgxwDgabQ.QCqQCnjTAETFnJMAkDBTm1tcVlMqDlreWUEndsssqZCqQsGHIDTgdXMBr55nAz9PMvo.PeW8FRUAMHJ6ncVdsZUSf5k2V6JDFnB7Pp0hEo4Kmkdn95vIUfNnUPbnflZsB5fBGR0xpWxGLtLGBrBNALv32FbDYCnSwQznzYY6WgGZS4gwTbV8Rt+ngGvwC11S++OnoCZLWLuXsk7xpZ24TuCsS2Nb+Cl6A9Ky8Fy+l6Uv8JHb0U97wYXg9JVH7A5sbwzqVUT9QSyWVjlOp7kh+7trNenS9pauJaAV7+Hc1J7CX2ee2NWMeU9XuT2jM85aJ57AC1897zwE2fR3zaeoyGvm+I9DEezrzkkMvXrF0ZkUCJIoOzCHhArADy.w.BXYxXsYv.Sh00dYKV5FqU0v7QeBK6eLcb1b7KGMe17E36SveToTp+i789hpQhS0scTTj8khUKxfwaGH4qlMyMVtY53wY4N0XETA0Qo25Jz+prPW7y4cP4XGpuvdwpayaRaIwBNY17OuiH9W2H.Z5uNOclqAVL+yMWUAU7RyVEuU5U7bNMRvrZtA0zRNCjdKAv3Q.iw.phJEJiVdfogyAvaZTbdLQvkBR+jXCQyGDmjP4b8.8S0z3w56oNRKfsCyORiv9q6wk6Yc1ZV9oESGewuVEm+dOV+.KSa042jtzyLYqnWMe9rshVrXU1ZwPhQGQr1M+oam8awfRrWi8PIHseRHgFwsFpPxoLAWy0ZK2iFDRaDnDRoxXDZkTAx5moFCbIQzS0izWoXDJzqehTNPCCG9bOS0iG1NToMOE8e6A.r2A.0C.X0..jBlG.XzBJvwu5bz9+e71e3wa+aqEacdEakZzMymNJamJcBiLg043FlJuzLvFon3aV.LRlaB3oOwLYf.MLzXN5mtuhLPY5KTIFJseucMLvi0vPaxxrgfSKsdaMa+ZJ1UbVN9Swx45ejwSuMKeYY5saJzNe31.KtHJq6xmPwbE5AwrdH.wodce0tZK+e1AbTFlqRP1wErsvHInhrFCkqYTKNI1igLP8Pld1dCQVW8wP6L5PB2hXFtpeeEu+yxbYZSA2wrDoW18U1yKqEIuGuDTxZfy8FO1ilEGhluZZw3r6bFr5cbfbYFcyE8mVbQrWTmoeVV93+2sHW8lJXuY2cS5Sct.kTJXc.xsTmueuk2og9E6+92DWTNp9c2LmVybkIoxHkPXrZgZKbVahLRq.nHHlqzLSSwp3VvRfI7IDqLyPDVJWMQYTBsXW7M64.eGHshO5xqn62oGNiJ1mHO.3LMuH65ccXUme4+Q1hqy7PY4KW1gf2TCBCDwwfaBiALqyQoxRyUTdYHwFxdLIoGQDyMDSRhjPS52C8pES6kj78H6wCSa7Wv5voJUOadENwPimv751RC5QN+Gifld6cyllecSE6uOMOKcQMdKbzYen2BNKB4GQQmELXmneXNORKSqQduJCSInMii5aQbTeFmX3C4jXZhHtmZvvgF0yd7v5.RHe+iLikuOOXu3agb+V1xJ8LS+lCs8M.noozHC0vE18iJosLJmZLbsw9lBkYdm29Sj2tkIiLVk.3bzOkXCnxF4.YJNvAAzLSGZrDS9yHSHFFOlnop3XY7vDiI9a.SdVWFxe900y1wjWzUTGS93oNMjGhae4WTgMahxQbd5WqoJHXqbwFFDxBl7HmBnqK6trvv.nBECctYsGABpLVKQzyNfXfd8IVgUyPtabgf9Mzs1Al75Ec69VU2R4MIc1xr5V54zBO3.BwNF6CO2AA8QT7aL0Qp4F89vBych9TyzxBfawmnVhMFhIxgFqIwJFLvumSOIiOpXtwIv45JI7JOGwMajXsqbma3bZ+6x0P0yxnF6tO4mentZRD0MllLewsdWVzW53YsdGIDQVlfxYVSEEmRWOTLVDR6gibhjZWrnF77XwHNhgl9DSeaLAKhJdfxzqm5YemiOVvgC1Rhe4tho2VwSFXuAHQvLVAlIjPv4x8BjX.PnsfvPCuayu4YQ.uudwGjAe3kJVGZohUQRj7Q4Vj4AcLtNxJsTKiYTxisoluuPwOCKTLveY8vUx.9Y0E2oloNiw3QV8t6QqKKcj7L2hXHpoL88WGt29QZG2d010Ot6+O58+28U1yKOV.IwqHNh3TDgkYe.qBSD21tkl30LGw9yRG8oK5+Sdkt9Ycq1Brqp.0h45qT50LwJOi.rH.nTElDuz3Uw0qKGzG5SDLw.hUMjSXrdlDUx.SL7j0kodNI0lGpK56U+4cU8pFz2cebm4yp5d2E49Nz3jcwFtRf4GNN7GFiC.CxlhqMBbt0FHBFlC.FmwO54P5sJC9mvhD6No2tid3ItkFaJVKH4rsYll+nZlo4ssYJW9ySqMZyRltoAV9orOep69iqHsr5KugRmXCTUnSnINY6PUgZUSDdwekhCOf3fIRaTTFUuyBvv0Z24CmBVpDzGI4IL7aLQPEBbBe7.RLjPi4z3gZyS9zWrFg2bPg0.zVb.EaVDGJoAIhjaLzsQpl6P0jLU5cN7A+s1oXl9zOE6dL6YvoXOBYZ4+AvgAvAPzLAwe2uP526uVOuiJpCU.QT2QmVgFXA05XtXqtoKPjDItvYZS0wh80IpPTgJjVLYG2tw0LpveyW7W4A9atq7vIAKXJkQBVICSgzkySErvJhrfgyDsXQaN2fE9aBA+L3lPvBdN93bMZujnmQX6545lGaQel7sGu8eXuJD72C+2zLZC2Z4X3+Jhod3gB3QXbeKEwGGaELd0dCl9s0aEOJk7aZ1jk6oyojOI7HSnb2VpcIy.OlbJ2YSpZcabhoUV1DunIVV1DsO0R3Qka41Vo0FjVmdoFnQLK9FRKu7zWezKkz2gzIOKNVJ0kk6dcdBqKwUny6+dYcoqedrkPMtJBejF4tS6un+dYsqSw4wAvZ9Qw4mSm8pp0z4v69SqOglDknxsYDxLFnBF5H0dr03HajRPDhIZxUBghLNCRo.PGIux7DcjVG8U2Q23mymL2Mb0eCuV.s9.ozX7qfGMV3Qn3YfUQD.p86oPEubPBGYXBX9lpW9M4ug6l5+L6Z+lUTcXbVsnjX+82+WnhdxvM
--end-wire-patch--
Not sure why it's formatting it like this. When I Don't use the "Code" formatting it's just ASCII??
ether
Re: Grid Cloner
Post by ether »
MarkyMark wrote: Sat Oct 22, 2022 16:01 Working on it :D
Awesome!!!
Look forward to seeing where this goes.
Also....
Some z-axis controls would be SUPER awesome :D
MarkyMark
Re: Grid Cloner
Post by MarkyMark »
Arvo's solution will work for now..
But there are waaaay better ways to to this incoming.
The grid cloner we're working on can easily create 100 clones without breaking a sweat. Ofcourse this will a Wire patch that you can customize as you see fit.
I've also been experimenting with other cloners like a Spiral Cloner and a Rose Pattern Cloner. These will probably not make it to Arena, but I'll probably make a video tutorial on them. There will also be a how-to-make-a-cloner tutorial in Wire.
I think that's about the amount of teasing I am allowed to do before I get hit over the head with a MIDI-controller by Bart :lol:
