UI Panel Positions causing MIDI map fails?
Phlux
Post by Phlux »
Does moving the Clip Grid BREAK midi maps, even though they were set "target: THIS LAYER?"
I had some buttons programmed to engage specific layers, including output midi lighting details, and it has been working for a long time. Now the buttons don't work, even though the "Deck" buttons, mapped to the same controller still work fine. All I can think of is that I moved a couple of control panels ABOVE the clip grid section temporarily.
Also, when I go into mapping mode, there is NOTHING mapped to those layer and group elements, as if they were manually deleted.
Please advise,
Christian
Re: UI Panel Positions causing MIDI map fails?
Which Resolume version are you using?
Is it the exact same composition as you mapped the shortcuts with?
