SPOUT Processing->Resolume MAX SOURCES
VjLuper
Post by VjLuper »
Hi guys! Do you know if there is any limit in the number of sources I can connect from PROCESSING to SPOUT?
Looks like I cannot use more than 10 (If I add more later overwrite the previous ones). Depends on some settings, or on my Card?
in this page https://resolume.com/support/en/syphonspout I read "There's no hard limit to how many applications you can connect like this"
THANKS
Re: SPOUT Processing->Resolume MAX SOURCES
What does your spout settings show as your max limit?
12 senders work fine for me, I have 64 senders set is SpoutSettings.
