recording to a specific clip on a specific layer
ision
Post by ision »
Hi everyone,
I don´t know if anyone thought about this or if there is in fact a way to do it, but if it is please tell me!!!
Sometimes you are doing some vj and you ended up with a composition of 3 layers and some effects, and you like it very much and you start recording the output, fine, but if there is a way for you to program Resolume like you hit record and when you stop record the recorded clip goes automatically to a specific clip on a specific layer? Is there already a way to do this? Can this be implemented in a future update?
All the best!!
Re: recording to a specific clip on a specific layer
When you hit record it should add it to the next free slot in whatever layer is selected.
Online
Arvol wrote: Thu Nov 03, 2022 23:03 When you hit record it should add it to the next free slot in whatever layer is selected.
Yes, that would be nicer.
