Adding TV to LED wall
Buhkee
Post by Buhkee »
Hello, I’m still new to advanced output mapping so thank you for bearing with me.
A project requires two 1920x1080 tv monitors in addition to a video wall to also display content. (Obviously the TVs will be driven from a second output, not the LED processor output.
Is this possible to add to my composition? I’ve currently made a composition that is 3840x2744. (This is 2x1920 for the TVs, and 1080+the height of the wall)
I have moved things around in input mapping and then chosen “match input shape” for the output. Am I doing this correct or is this even possible?
Thank you in advance.
Re: Adding TV to LED wall
Sounds like you're heading the right direction.
Once you have the composition laid out how you like, you can make new Screens in the Advanced output, and select the areas in the Input selection, which you want to show on the TV-s.
https://resolume.com/support/en/screens
