Sudden Resolume crash
knowmad27
Post by knowmad27 »
Hello. I was on a show and suddenly Arena Resolume 7.3.2 rev74029 crashed while it is IDLE. Was running a DXV loop for about an hour then Resolume suddenly closed. It happened multiple times while running the show. Here's the log:
*idk why i can't attach the txt file so pasting it here. Here is the recent timestamps before it crashes. hope someone can help me so i can prevent it next time. thank you
[2022-11-20T09:27:07.786+08:00] INFO: Done reading sync data, cleaning up
[2022-11-20T09:27:07.856+08:00] INFO: Successfully read composition xml
[2022-11-20T09:27:07.856+08:00] INFO: Reading composition state took: 0.53083 seconds
[2022-11-20T09:27:07.856+08:00] INFO: Setting composition high quality to: false
[2022-11-20T09:27:07.856+08:00] INFO: Default color format is now: RGBA8
[2022-11-20T09:27:07.857+08:00] INFO: Composition loading finished, result: true
[2022-11-20T09:27:07.857+08:00] INFO: Loading startup composition finished
[2022-11-20T09:27:07.862+08:00] INFO: Application successfully initialized
[2022-11-20T09:27:07.862+08:00] INFO: Initialise took: 7.44868 seconds
[2022-11-20T09:27:07.966+08:00] INFO: OpenGLCanvas: New context is created
[2022-11-20T09:27:07.966+08:00] INFO: Initializing GPUMonitor
[2022-11-20T09:27:07.967+08:00] ERROR: No valid GPU Monitor Strategy could be instantiated, max/used memory will always report 1337.31415.
[2022-11-20T09:27:07.967+08:00] INFO: Initializing renderer.
[2022-11-20T09:27:07.967+08:00] INFO: Loading shaders...
[2022-11-20T09:27:08.004+08:00] INFO: Successfully loaded shaders.
[2022-11-20T09:27:08.006+08:00] INFO: Successfully initialized renderer.
[2022-11-20T09:27:08.155+08:00] INFO: Enumerating Compositions took: 0.08048 seconds
[2022-11-20T09:27:12.874+08:00] INFO: Auto-saving layout
Re: Sudden Resolume crash
Could you please use the crash reporter dialog that pops up after the crash to submit a crash report?
That way we get lot more detailed information about what went wrong exactly.
Don't forget to fill out your email address, so we know it came from you ;)
