OSC Sync clip repeating.
ceecrb1
Post by ceecrb1 »
Just programmed a show, decided to try out OSC to sync a backup machine.
During the show, I have a section that does not play properly when triggered via OSC on the backup machine.
Should be: (2 layers)
Column A. Videos on loop.
Column B. Transition video, play once and clear, autopilot play next clip.
Column C. Play video, once then clear. Set to ignore trigger cue so can hit "next column" like a go, ready for the next column D later on without affecting playback
On the main machine, all is perfect, both layers sync up enough to not need tc or anything.
Backup machine identical when triggered via keyboard or mouse etc directly.
Backup machine when triggered via osc, will play one of the transition videos twice, the other just plays once.
Also when I press my "go" via OSC (next column) from master, the backup machine acts like ignore trigger is not enabled and restarts the video.
Suggestions?
ceecrb1
Re: OSC Sync clip repeating.
Post by ceecrb1 »
Video showing the issue:
https://youtu.be/F37mxpM_XIo
I'd recommend setting up a specific OSC shortcut preset on the master, to only send the data you really need.
Otherwise, the auto pilot setting will also be sent over, and then the auto pilot will fire on the slave too, and might advance two clips.
Also other weird stuff might happen: https://resolume.com/forum/viewtopic.php?p=79966
ceecrb1
Post by ceecrb1 »
10 points to gryffindor!
Spot on and an easy fix!
