Silent FFT from clips
Joshuasch
Post by Joshuasch »
Is there a way for me to have audio from a video silent while still using the audio output from the clip as input for fft?
Is it also possible for me to mute the audio output from a layer or group?
Re: Silent FFT from clips
Check the view menu, and enable show Audio controls, this will show audio faders for layers and groups. You can use them to mute the layer audio.
