Screen Mapping
trossenink
Screen Mapping
Post by trossenink »
Hello,
New to Resolume, but very interested in using it. I have a newbie question that I haven't found the answer to. Does Resolume do screen mapping? But that I mean can I overlay a video image across multiple screen/monitors/projectors?
For example, if I had a graphic of a ball running from left to right in a loop could I apply that graphic to a dozen screens that are mounted around the walls of a room so that the ball is circling the room?
I will have different setups with TVs, monitors, projectors, etc so I'm looking for a solution in which I can map graphics across them in many cases.
Re: Screen Mapping
trossenink wrote: Sun Dec 11, 2022 03:29 But that I mean can I overlay a video image across multiple screen/monitors/projectors?
yes, https://resolume.com/support/en/advance ... on-mapping
