stutter effect on video clip
jakemelon
Post by jakemelon »
What is the best way to create a stutter effect where a video clip advances X number of frames and then reverses Y number of frames?
This would create a type of a stutter effect where video clip would play forward for 5 seconds (x) and then reverse for 2 seconds (y) then repeat.
thanks
jake
Re: stutter effect on video clip
Buffer nodes in Wire should get you there.
jakemelon
Post by jakemelon »
Not using Wire at the moment, any way of doing it in Avenue?
Not effectively. Maybe MIDI map the "Transport Position Behavior Play Mode" to go between normal and random? There's also the Stop Motion FX but it's not really what you're after.
Delay RGB, with all 3 set to the same value and animating the effect opacity could jump back in time, though not play backwards.
jakemelon
Post by jakemelon »
Interesting, I will try that.
thank you!
