Clips stutter when layer master is brought up..
DaneDog
Post by DaneDog »
My clips will pause for about 1 second and then continue playing, but only happens when the master is brought up.. This started happening yesterday after building the composition over the past few days.. It wasn't an issue when I first started my composition.
This won't happen on a empty/ new Resolume composition.. So it's something with my current composition, which wasn't happening when I started my file a few days ago..
The Resolume file is nothing big. I have 11 decks, each deck is a song with a handful of clips and effects on each deck.. And my PC is pretty good..
AMD Ryzen 7 5800x
GF 3080TI
32GB Ram
Has this happened to anyone else??
Re: Clips stutter when layer master is brought up..
Does it also happen when the clips play with master on, and you turn master down, and back up quickly?
najork
Post by najork »
Are you using still images as masks or overlays?
Sometimes those being suddenly loaded into memory can create lag.
