Custom osc output in same clip position in other deck
D.pi.T
Post by D.pi.T »
Hi everybody,
I try to send custom osc message to an other software. I create a solid color with osc out in first clip in first layer in first deck with custom message "/out1". And I want an "/out2" in first clip first layer in deck 2 but it have the same "/out1".
Someone have an idea.
If it's impossible I create an automotion to Trig specific clip.
Re: Custom osc output in same clip position in other deck
how do you have the shortcut set up?
D.pi.T
Post by D.pi.T »
Hi.
I find an alternative. I create a wire patch to send custom string and value over OSC.
Thx for your attention.
