LEDs constantly flicker (Advatek Drivers)
dxcade
Post by dxcade »
Hello there,
I have a fairly large amount of LEDs that I'm trying to run through Resolume that are currently being ran by Madrix without issues.
I was able to connect to the LEDs, but I have an issue of them constantly flickering. They are receiving the data and will change to whatever I have running in the channel, but even using a static color they flicker non-stop. If I switch back over to Madrix they work just fine.
I also noticed they don't dim using the sliders, they are either on or off, toggling around 30% on the master.
I am very novice to all of this, so I'm guessing I have some setting wrong somewhere. I've searched here and google and couldn't find any mention of this issue elsewhere.
Any ideas? Thanks!
Re: LEDs constantly flicker (Advatek Drivers)
Sounds like the leds get conflicting data from two sources, or they can't handle the 40fps DMX data.
Lowering the send rate in Resolume could help in that case.
