Advanced output cant rename fixtures
jiafoongwee
Post by jiafoongwee »
Arena 7.13.2 rev17774 23 September 2022
Windows 10 19044.2364
Working on some pixel mapping. I was trying to rename the fixture in the Advanced Output section to have a more visible label for my pixel strips. But it keeps reverting back to the original names. I first thought it was my negligence for not saving them, but turns out Resolume doesn't save the names after you close and reopen Resolume Arena. This also happens if you hit "Undo" to any changes regardless how deep the undo queue is in the Advanced Output, as long as you hit "Undo" it will revert the names.
Undo Issue
Save Issue
vejas
Re: Advanced output cant rename fixtures
Post by vejas »
Have you tried to save the output map, before close resolume, make a copy of the xml (on desktop), close resolume, load the xml where you saved?
jiafoongwee
vejas wrote: Sat Jan 07, 2023 22:35 Have you tried to save the output map, before close resolume, make a copy of the xml (on desktop), close resolume, load the xml where you saved?
Yes, Same issue
Thanks for letting us know, made some tickets ;)
