Camlink 4K not working (Windows)
_Ineffable_
Post by _Ineffable_ »
I want to use a Camlink 4K as input source.
However I cant seem to add it to the project in resolume on windows. (Tested on multiple machienes)
It does work as it should on Mac.
The only current workaround is inputting it into OBS and route that to Resolume through OBS Virtual camera. However this uses a lot of CPU and is potentially unstable and therfore undesirable.
See the GIF below demonstrating the problem;
Yeah don't worry! I put it on autopilot!
Re: Camlink 4K not working (Windows)
Could you please send us the Resolume log file via the feedback tab in preferences?
HeartHMX
Post by HeartHMX »
Absolutely same problem with EzCap Camlink 4K
Hari15901
Post by Hari15901 »
I had this same issue . Camlink is working with other software like vmix obs etc. why this issue in resolume
Harmzk
Post by Harmzk »
is there a work around for this now?
as i recieved my Cam Link 4k today and it works with everything else except Resolume Arena?
works on my Apple Mac but not my Windows Laptop
Christoph
Post by Christoph »
This issue should be fixed in the next release.
Workaround for now would be to grab your capture-input with something like OBS and then send it to Resolume via Spout or NDI.
Harmzk
Post by Harmzk »
Thanks for the reply!
do you have an ETA as to when the next update will be out?
thanks
