Alley conversion options missing
kaminskavisuals
Post by kaminskavisuals »
Hi!
I've just bought a new computer and moved my Resolume license on it.
I need to use Alley to convert my movies, but the only option that is showing is DVX Normal Quality, no Alpha. The three other options (high quality, with alpha) are missing.
I tried uninstalling and reinstalling it.
Am I missing something?
Thank you!
Re: Alley conversion options missing
We're working on some issues with the presets, meanwhile you should be able to save your own presets.
Which Resolume/Alley version are you using, and which OS?
