Recording Speeds Issue
ghog
Post by ghog »
In the past I have had no issues recording out however today when I recorded a composition the speed was about x10 of the clip. The composition speed is set to 1 so I can't work out why this is happening. I also started a new file with one simple clip and when I recorded that out it has been sped up. I also tested with various frame rates and the problem persists.
Re: Recording Speeds Issue
Sounds like the frame rate of your composition dropped below 30, and the recording was dropping frames.
https://resolume.com/forum/viewtopic.ph ... +up#p79212
We'll be reworking the recording function, we'd like to address this issue too with that, unfortunately not all formats support variable frame rates.
