Spout slows FPS
thunderingjack
Spout slows FPS
Post by thunderingjack »
Hello, I'm using Resolume on a i9 PC with a RTX 3090 GPU.
Whenever spout is enabled my FPS slow to almost half?
Composition is set 1920x1080 @60
3 outputs - 2x 4k60, 1x 1080p60 (GUI), This normally works with little effort.
At a bare minimum, I can open a new blank composition, output disabled, runs at 60FPS.
I switch on Composition Spout output and the FPS drops to high 30-40's?
Any ideas?
Thanks,
Stuart
Re: Spout slows FPS
Could you please send us the Resolume log file via the feedback tab in preferences?
thunderingjack
Re: Spout slows FPS
Hello, I've just upload thru the feedback portion on Arena. It happens every time I load Arena unless I use the 3rd party Spout setting app and reload.
Re: Spout slows FPS
Is your spout receiver running on the same GPU as Arena?
What do you change in the Spout settings app?
thunderingjack
Re: Spout slows FPS
Hey Zoltan,
I can confirm the GPU render is coming from the RTX 3080.
Here are my Spoutsettings -
https://lh3.googleusercontent.com/drive ... zXYK=s2560
Re: Spout slows FPS
Increasing the buffer could help a bit.
Which app are you sending to?
thunderingjack
Re: Spout slows FPS
Hello, did this ever get fixed? Im on another new PC win 11, same problem. RTX3080.
According to Spout Demo Receiver - Arena is using DirectX 9?
This is very problematic on big shows.
Am I missing something here?
Thx
Re: Spout slows FPS
You can change DX settings in the spout settings in your file browser
thunderingjack
Re: Spout slows FPS
Hello Avrol,
Are you referring to the SpoutSettings.ini file?
Thx,
S
Re: Spout slows FPS
There should be a spout settings app with a small GUI.
