Playback not synced if clip doesn't have audio (Minor bug, don't waste your time, just reporting)
Full Spectrum
Post by Full Spectrum »
Minor bug.
If you have a clip (dxv no alpha) without audio paired with identical clips with audio, they'll fall out of sync eventually.
About 2 seconds per hour. So... super minor, but worth mentioning.
This is the first time I've had such long clips, so I never noticed before.
Thanks,
Re: Playback not synced if clip doesn't have audio (Minor bug, don't waste your time, just reporting)
Clip timelines are not synced to eachother.
If you need very tight sync, I'd recommend SMPTE
