Output not 100% Black Having some grey
samithra10
Post by samithra10 »
when I connect my laptop or PC to video screen (LED Screen) when I make Master output 0% screen not getting 100% black, it having slight grey output.May I know the reson for this and how to fix it.
elgarf
Re: Output not 100% Black Having some grey
Post by elgarf »
Maybe this will help you. Or you can try change contrast on led processor.
https://www.reddit.com/r/nvidia/comment ... nect_your/
AngeloDV
Post by AngeloDV »
This sounds like the common full / limited setting with Nvidia cards.
Check Nvidia Control Panel > Select screen and check below if it's set to Limited or Full Range
As Angelo stated, 95% of the time it's your GPU outputting a Limited RGB range (16-235) vs a Full RGB range (0-255). This is used mainly for TV's as they don't typically need or process 0-15 in the dark range, for LED's though this is much more sensitive and is needed. Check your GPU settings for this.
The other 5% is when you're using junk signal flavor converters like BMD micro converters, that force a limited range when using them. The soluton for this is to use better hardware like Decimator or AJA.
samithra10
Thanks For the Great Answers guys..very helpful and valuable answers for very bad experience on stage on Blackout am in grey.. :ugeek: :ugeek: :idea: :idea:
