Resolume is not using my GPU
LynnetteEvans
Post by LynnetteEvans »
Hi everyone I have a question.
If you can help that would be greatly appreciated!
At the moment I am having trouble getting resolume to use my gpu.
In my task manager my GPU is running at 25% at the highest continually and jumping and my CPU is 18%
I am using a sager laptop
I am getting flashes in my output preview.
How do I fix?
Please help.
Thank you!!
Buhkee
Re: Resolume is not using my GPU
Post by Buhkee »
Does this happen when you have display or processor connected to your HDMI port?
Can you post the specs of your laptop?
If you click Output>Show Display Info
What does it have listed as your rendering GPU? If it's not your dedicated GPU you may need to check your application prefernces in your GPU software.
