Network trigger from Resolume to Madmapper/ 2 macs
eratatat
Post by eratatat »
Hiya.
Sorry for the basic question here.
I have one Mac running Resolume Arena and would like to make it the master to a slave computer running madmapper. My cues are basic (next column on resolume should trigger next column on madmapper).
I understand that best way is to link them with ethernet cable and go for osc? I also found midi audio setup in a tutorial, but not sure if I can send out midi signals, that was possible with Ableton.
Re: Network trigger from Resolume to Madmapper/ 2 macs
shudder_inc
Post by shudder_inc »
The Audio MIDI Setup app in macOS should be able to do this for you. Once the computers are set up, the network session should show up in preferences as a MIDI device. Then set Resolume to output and MadMapper to input.
https://support.apple.com/guide/audio-m ... ms1012/mac
I used the above link and with one computer started a session, launched Resolume, and the network session appeared as a MIDI device. I've no MadMapper experience but I imagine it's a similar process
