Display current time over video
SAMalashenko
Post by SAMalashenko »
I ask you to tell me whether it is possible to solve the problem of displaying the current time transmitted via the NTP protocol over the video. Or do you need to pre-form a separate layer with the display of the current time and overlay it by mixing with the ALFA channel?
Re: Display current time over video
You mean the system clock?
You can make a Wire patch for that ;) https://resolume.com/software/wire
--begin-wire-patch--
707.3ocqU88bhBCD9eEm7LLCD9suAJ95cy09VGeHBQIyESbHg150w+2uMfHnVqsWOcTHgucyt622t7FpPJDzBMSJTnoO8FZcsbKbiiEpR1TqPKsPZIrgqEhI10ncPKOXMF1VlnQSuFn6k.UT3rJuFH9LfvtxFc2AcDH9Hvyvg6wcBl2.LXKgrDBpougbL+Qz5Z1p13DVo2uiNbs6hE5YBuwrjIzzMzZzgCVnUxFSHCXqnrMUZzTWOHUdgUpqf6SBrPuhlFGag1CKCwfIEbhp0BVI3rnnvjHbXfsqehmseTzb6jX2L6HufE4QtIo9yyLmMsVAT.ZpSqGjE+Fr8YVIUBOrPxk0v50vmPhiS6VBklHzlCBrnhUVRAqexj3jslr3g8JMc6jGYvJ.g60Ug0b4KipBsKGpBJ1FAgaLsi1sKAOITc5jSFMZySl9zxdib+WLB+EMRw9yXxTzrcEPdmv384oQunv6yiAwAXaOuzL63DZf8h.LA6WPvkANeSdru+ZHWT.cI1LhTNQGteJT36gRQ2QpIZSTcafSa6DdGI1LonfnoB3mwY3qkXqX5R5NSM9j6Kpjrhwsa+jnKpljwzSl2BE7zZoP+QljVy5kllpWw3t5qD.t.tZpRxazsLy8hjGL5ISsQumS+H3YRd4sFRD3ek5Jzy+9pqbb9La+Ev.hDG2T6Y4Kl4G4O2alSz2UcQ3PGMzCMtx1Op6rh0p86NFaGQsRJ4CPVS3JZuB6izMOReUaJjblfdrVLdXCQO5XSvlTZKnjZo1K.5Opk20p8aameA4LF5RmZfriTXhpK.gG4PGKmkmIv6K.CBcSlL4WTQo4sBVHuqE5eNg36pUhwCREOb26S7i5jJQg2VpjkmmZCRiX6377.am7rT+YYycRyy+uLHZ7KHg7uolhKGRFQCmeiwBO1gdxO.eb3XyWScWs4vg+BDpStBI
--end-wire-patch--
But he would need Wire for that right? ;)
yes, if you have Resolume 7.4+ you also have Wire installed.
A Wire license would be needed to run the patch without watermarks. It's free to try.
Or pay someone $50-100 for an hour of their time to have it built or compiled.
