API calls - inconsistent clip connect
slopes
Post by slopes »
I'm trying to do a simple API call to a local instance of Resolume Arena from the Swagger test interface on the same machine.
This is the Request URL for the "Connect the clip by its position in the clip grid"
http://192.168.1.XX:8080/api/v1/composi ... /1/connect
I'm not able to consistently to get it to work. I've reinstalled the latest version of Arena, started on a blank project, and it still is all over the place.
I'm able to start with Clip 1 on Layer 1 by issuing an API call. Then I go to Layer 1 Clip 2 by executing the API call from Swagger. All good so far. It goes forward on the same Layer fine. Clip 1, 2, 3, etc.
Then, I try to go back to Layer 1, Clip 1 from say Clip 4. Doesn't work. Server response says 204 but the clip doesn't move.
What am I missing?
Re: API calls - inconsistent clip connect
I'd guess you only send the true value.
Whether to connect the clip. This is analogous to whether the mouse is pressed down on the clip. If omitted, true and false are both send - as if a short click was generated
With true only it's behaving like the mouse button pressed. You need to release it first with false.
Or simply not send the true/false.
slopes
Post by slopes »
You are absolutely right. Thank you.
