Capture Card Not Showing Up In macOS Without Restart
juicewon
Post by juicewon »
So i keep running into a serious bug when I plug in a capture card and it won't show up in 'Sources' until I unplug, (which obviously can't be connected in a clip slot). I plug it back in and the option disappears in 'Sources'. Rinse and repeat until frustrated enough to restart with card plugged in and it behaves as expected.
Happens the same with Magewell, Black Magic Atem Mini Pro and Chinese knock-off dongles.
Apple M1 Max. 64 gb. 2tb, Ventura 13.0
Arena 7.13.2
Works fine on my RazerBlade 15 and 5950x/3090 desktop custom build.
Any ideas on how to solve this problem?
5950x 3090 FE 128gb DDR4 2tb NVME X3
M1 Max MacBook Pro 64gb 2tb NVME
RazerBlade 16 4080 32gb DDR5 4tb NVME
Re: Capture Card Not Showing Up In macOS Without Restart
We'll see what we can do, meanwhile, I'd recommend plugging in your devices before starting Resolume.
Plugging in another USB device might help refreshing the devices list too.
Qcontinuum
Post by Qcontinuum »
I had same problem but in Windows with elgato hd60 s+ .
Solved connecting HDMI source ti the capture card before connecting to PC.
