Magewell Pro Convert for NDI to HDMI Problem with crossfade
Holm
Post by Holm »
Hello,
I bought a magewell ndi to hdmi converter to simplify my workflow, no extra computer, just a converter, simple.
But the fades from column to column look awful. I have tried a few settings, but no improvement.
Does anyone have experience with these devices and can give me a tip on which settings I need to change to achieve a better result?
thank you in advance
Holm
Re: Magewell Pro Convert for NDI to HDMI Problem with crossfade
They might have issues with the alpha channel.
Try checking the black BG option for your slices in the advanced output - output transformation.
Holm
Post by Holm »
BG did not help, but the new resolume version did.
Unfortunately, I can't update at the moment.
But I have found a workaround.
I output the image to a local monitor and record it with NDI Screencapture.
This way the Magewell understands.
