Hi forum,
In the advanced output there is an option to save different output presets.
Is there a way to recall these presets via some kind of trigger? I would like to load the content on all the layers in a column, and a certain advanced output preset, all in one go. It would be ideal if the presets were to be reachable via the web API or OSC, to load them with some buttons, like a stream deck.
Switching advanced output presets
florisdaelemans
Re: Switching advanced output presets
What would the specific presets do differently?
Slice Transform should get you. Or StageFlow if you like to be a rockstar
dirtyjohn_lv
Change brightness for outputs, different mapping for different use case (DJ vs corporate vs band)
Slice transform will indeed probably do what you'd like.
florisdaelemans
Thanks for all the replies!
I tried Slice Transform, and it is indeed very useful for the goal that I am trying to accomplish.
The Slice Transform effect on the composition or layer was not giving me the right result, but as a clip effect it does exactly what i want.
I would also find Advanced output presets (and switching them with MIDI) useful,
since they would also switch on/off the output masks (which cannot be controlled with Slice Transform).
thank you,
L.
thank you,
L.
Cursor Video
just going to add to this and say accessing Advanced Output functions via OSC would be really useful.
Use case, a job yesterday, involved a spectacle show that was a full pixel map render across multile outputs, played once, with a few misc moments - THEN a switch to a VJ show, which for efficiencey was smaller content (1 of 2 identical gauzes that were facing each other) - so the VJ content was in a group with all content layers pushed to align bottom of the output, and a video router pushed up and flipped.
so we had unique group/layer setups for each of the 2 main requirements, a deck for each of the contents, and advanced output mapping preset for each.
The switch was fine to do manually, but it could have beens seamless flow from the finale end in to the VJ show, using Companion and a Streamdeck I could switch decks, layers and play first coloumn in the VJ content group in 1, but not the output preset switching.
