USB-C to HDMI on MacBook Pro max m1
YH97
Post by YH97 »
Hi all,
I have a strange problem with my MacBook (pro M1 max) 1x HDMI output and 3 times usb-c
Outputting on the HDMI side is not a problem
I run from HMDI out to HDMI->SDI converter (black magic mini converter SDI to HDMI 6G)
SDI cable until the scaler, there I go from SDI -> HDMI (black magic mini converter HDMI to SDI 6g)
HDMI in on scaler and from there to a led screen wall
When I use my direct hdmi output I have zero problems
When I use my usb-c to hdmi converter (apple multimedia converter) the problems start
My MacBook sees the first converter (just like the case as I use direct hdmi)
Resolume sees my second screen connected
But it only gives a black output....
I tried multiple usb-c outputs, and a different usb-c to hdmi converter
Have any of you had the same problem?
Maybe you found a work around
Second thing:
Is there any plan of resolume going to MIDI Timecode or Artnet timecode?
I know that smpte timecode is being used for resolume
but with the productions of the band I'm working with, everything goes through Artnet
Anyone knows more of this or a work-around?
Thank you in advance!
Re: USB-C to HDMI on MacBook Pro max m1
Is it USB-C internally or thunderbolt / DP?
YH97
Post by YH97 »
Zoltán wrote: Fri Mar 03, 2023 17:14 Is it USB-C internally or thunderbolt / DP?
Yes the Mac is thunderbolt, the converter is clear to use on thunderbolt as well
Contact me for rental of led screen in the Netherlands
https://ledssea.nl
VJ/Designer and Technician
Touring with https://madmenband.nl
Freelancing: Europe
It might be using usb-c internally though, and that has caused issues before.
Which converter is it exacty?
YH97
Post by YH97 »
Apple Usb C Digital AV Multiport Adapter
https://www.coolblue.nl/product/608152/ ... apter.html
https://ledssea.nl
Freelancing: Europe
YH97
Post by YH97 »
Zoltán wrote: Mon Mar 06, 2023 11:39 It might be using usb-c internally though, and that has caused issues before.
https://ledssea.nl
Freelancing: Europe
How are you trying to send the output to the HDMI, via the Advanced output, or Full screen?
YH97
Post by YH97 »
Zoltán wrote: Thu Mar 09, 2023 15:54 How are you trying to send the output to the HDMI, via the Advanced output, or Full screen?
Advanced output
When not working with the ub-c to hdmi converter it works
When working with usb-c to hdmi converter it doesn't work
https://ledssea.nl
Freelancing: Europe
Could you try creating a new Advance output preset, or send the output via the Full screen output option?
