Iphone Footage to Resolume
VJH0
Post by VJH0 »
Hello!
So I'm trying to drop iPhone footage into Resolume, but the video won't show up; The audio is the only thing that comes up onto the Resolume clip slot -- and I tried to put it into Alley aswell to convert it --- but again only the audio!
Does anyone know what's happening here and if there's a workaround?
Android footage works fine!
Many Thanks Geee's
VJHO
Re: Iphone Footage to Resolume
We're working on h265 / 10 bit video support.
Try converting the files to DXV using AME.
I can't even get Adobe to work with their videos. Wish they would use industry standards like the rest of the industry...
resolumejunkie
Post by resolumejunkie »
Arvol wrote: Thu Mar 02, 2023 14:53Wish they would use industry standards like the rest of the industry...
omg. I think you’re serious!? That’s funny!
EDIT: Oh wait. I see what you mean now. It's not the 10-bit HEVC that's a problem. And, it's not the Dolby Vision 8.4 that's a problem. Both are industry standards endorsed by Google and supported in Android OS.
https://developer.android.com/guide/top ... ia-formats
https://developer.android.com/training/ ... eo-capture
Additionally, both are supported in DaVinci Resolve on Windows and Mac.
The issue appears to be on Adobe's side of things.. the lack of support for Dolby Vision. But, I did notice a third-party product to alleviate that pain point, on Windows. Here it is:
https://www.drastic.tv/productsmenu-56/ ... -for-adobe
