Duplicate effect
rawdesigns
Duplicate effect
Post by rawdesigns »
Not sure if this already exists but I’m looking for an effect to be able to duplicate a logo X amount of times and place, scale, rotate each duplicate individually. I know this can be done using slices and bypassing but looking for an effect I could drag into a clip. Thanks!
edwin
Re: Duplicate effect
Post by edwin »
The newly added Grid Cloner shipped with 7.14 might do what you need.
And if it doesn't you can edit it and make it suit your needs in Wire.
rawdesigns
Yeah I notice that’s probably the closest effect to what I need. I’ll have to dive into Wire and see if I can get it to work just need more Wire experience
edwin
Post by edwin »
We would to help you with that, also our Slack community is quite active lately and i'm sure people will be able to help you out.
rawdesigns
Where do I go to get help? This is something I wouldn’t mind paying for. Send me a direct message.
Using slices, it this could be pretty versatile, and you'd only need to make the effect once.
If you want to place the copies manually, that's a bit more setup time.
Do you know how many copies you need beforehand, or does that change with every gig?
