Play Clips dependent on date and time
Frischvergiftung
Post by Frischvergiftung »
Hi!
We have this long time video installation running in a loop (Clip A). At certain dates, for example June 6th from 9 to 10 am, we want to automatically switch to Clip B. After that back to Clip A.
What kind of solution (maybe some third party OSC Sender) can you think of? Or is there a resolume Plugin that can do that?
Maybe using Wire? I see theres system date and system time nodes...
Any ideas welcome!
Cheers!
Re: Play Clips dependent on date and time
Wire as standalone could do it indeed using the Date and System time.
Frischvergiftung
Great will try both! Thx!!
