more parameters for slice delay
visions
Post by visions »
I want just that:the way to adjust delay time, flip or mirror, or other parameters that are present in slice transform. That would be very useful!
I tried modifying it in wire, but with no luck.
dsquareddan
Re: more parameters for slice delay
Post by dsquareddan »
+1
Slice Delay is the exact effect I needed today, but no way to adjust the timing of the delay between slices. Feels like a huge missing feature for this effect
tijnisfijn
Post by tijnisfijn »
Here you go guys....
Slice Delay Pro by Tijn.cwired
(32.61 KiB) Downloaded 263 times
I hope this helps you guys out... Watch out with the frames though because this is a real potentially frame killer.
If the delay frames is set to 1 and you have 20 slices, your buffer will be 20 frames but if your set the delay frames to 5, your buffer size will already be 100 frames. Keep this in mind.
I also built in a extra mask mode. This way you can use a normal slide transform before, and used the mirror and flip options from that.
Have fun with it. I hope it helps you guys out.
