Hello,
Has anyone else noticed that Alley in these last few updates has been slower to convert files?
In addition to being slower, I'm noticing that it no longer does 3 files at a time, but only one.
The old version was able to convert and use Resolume at the same time, but now I feel Alley is much heavier.
Does anyone have any tips on how to improve this?
Alley 7.14.2 - slowness
Re: Alley 7.14.2 - slowness
Thanks, Yes, we're working on the conversion.
samirbridi
It cost!
Alley is a great tool, and with this new form of conversion that you put in it, it has improved a lot, but it still needs some adjustments and nothing better than us users to pass on this feedback.
The conversions, in fact, are all perfect, without any problems. The fact is, the program doesn't make more than 1 or 2 videos very often, and due to this change it ended up becoming a little heavier.
As an observation, if you can, put a window for preferences, where we users can choose some situations, like:
- Play or not the videos automatically
- Amount of conversion (videos) in queue
Another issue I remembered... when we try to modify the conversion type and would like to save it as a profile, it is not accepted, simply just what comes with Alley.
