Footage an led wall set up
Mark Santangelo
Post by Mark Santangelo »
Hi
Am new to this software an would like know what best way to set it up an which quality footage content to buy.
Am using a 2.5m x 1m led wall which is P4.8mm
Have placed behind the dj booth.
As some footage looks really bad an others looks quite good.
Is some steer well clear of an other to look out for.
Cheers
Mark
Re: Footage an led wall set up
You can calculate the resolution of that panel using it's size and pitch, that will give you the resolution you'd need. Higher resolution than that won't look better, but you could have some freedom to zoom in.
