Reference input on Blackmagic decklink
akkronik
Post by akkronik »
Hey guys,
I was wondering to know if Resolume could be use with my Blackmagic decklink's reference input ? If yes, is it something automatic or I need to configure something ?
Does Resolume can be use with genlock ?
Thx all
Re: Reference input on Blackmagic decklink
Resolume doesn't support external syncing currently.
You might not need it in software, if the card can do it.
