Has anybody used it can say something about the color feedback of the buttons inside Arena?
Thinking about of buying because I like to have 16 clips next to each other on 4 layers.
Akai Professional Fire - LED Feedback
OnlineZoltán
- Team Resolume
Re: Akai Professional Fire - LED Feedback
This one?
https://www.akaipro.com/akai-fire
https://blog.segger.com/decoding-the-akai-fire-part-2/ says FL colors the buttons using sysex.
Resolume won't do that, but as Akai hasn't published the usual programmer's guide for the controller, it's hard to say if it would react on midi note velocities to light up the buttons.
Maybe Akai support can help you there.
Thx Zoltan. I understand this as an maybe. I will take a look to the local stores. Maybe there is on in stock and I can try.
If I can find one to test, I will post the results in here.
ArtGateOne
i make translate code - u can use now Akai Fire with Led Feedback
https://www.youtube.com/shorts/zuxOBPjDtqY
