OSC to sync clips internally.
ceecrb1
Post by ceecrb1 »
Just trying to play about with playhead position/ frame sync 2 clips together internally via OSC.
Same machine, clip each in it's own layer.
In simple I want to be able to play various clips, but one clip is the master clip giving it's playhead position to other clips to slave off in one resolume deck.
I've enabled OSC input and output, tried setting ip to network ip, loopback and manual IP.
So I'm taking playhead position of clip1,layer 1 osc, enabling output with target of layer 2 clip 1.
so:
/composition/layers/1/clips/1/transport/position
and outputting to:
/composition/layers/2/clips/1/transport/position
No joy.
What could I be missing?
Re: OSC to sync clips internally.
You need a translator as OSC loopback is disabled. Try Chataigne.
ceecrb1
Post by ceecrb1 »
Spot on!
TBH another feature that would be nice to have internally, just internal sync busses... I wonder where I got that name from...
There's a feature request called "Global Parameters" Go give that one a +1 as you can link one param to another (exactly what you are asking for) ;)
Cursor Video
Post by Cursor Video »
where can I find the feature requests page to add a +1 for Global Shortcuts?
Or has there been any alternative development for a means to send a single parameter value out to multiple OSC addresses yet? I can do this to 1 via the Param to OSC, and I can make use of the envelopes externally by sending 1 POSC to a second POSC and then out, I'd love to be able to also send those values internally.
tijnisfijn
Post by tijnisfijn »
he are you on a mac or pc?
