Text color
rawdesigns
Text color
Post by rawdesigns »
Was wondering if it’s possible to change the text color of individual letters within one text block clip?
Re: Text color
Not that I'm aware of.
You could use the text as a mask over a custom gradient or use wire and instances but neither of those options are probably what you're after.
rawdesigns
Re: Text color
Thanks I’ll keep toying around. I basically have two rows of text and I want the top row to be different color than the bottom but it needs to be in a single text block
Re: Text color
Maybe something like this?:
Code: Select all
--begin-wire-patch--
2801.3oc6b01aaiiD9uRf+roAeWT8KGrkkuaA1q6gt8vdGVTbP1VIQWkk7II21rE4+9MTR1VxllRtwoMsqCxGbTFNjbddlgyPR4OOXQZRR3hhnzj7Au52+7fayRWAefNbP5lh0aJF7tgCJRgmPFNHJo7AONbmXLShEGkD9wnkE22RTtIQChitKYUXRas5bjnt0cNtkbpSJGokbtl5570AKhRtqkfDrQIWDDG1VNxwxQMYeLnOi1QxwFRnoKRiSyZOUH7SJHsKjQdFPi7TXiqQY6qwTZzZJLJ3wVIpAMpLh3TC.jYtgAAcLhPxiDjZDxIGyJoLiyFXZmElmFuQ68sWXkQg2oUxdIMOinGCQToQ+GSRxze.sJ3Sskb2rGejnQIsm+GqTF13TxfN0RZPmTy5zz.kcrR0.ZQVPRdbPkktoaB1vDidZ4INFFzTyVWpEQaCYLChpCTrJH+8ffuqtQ+R1xvrxfyrg7gNCUCAeLHzADT.7g.uCJADcUXQvfW84AAaJtOEDev.H.QPQ3coYOL3UIahiGNXY353zGzN2uMH6tvBs7ygo7h6qjOIXUH7oeKJKD9qODlkqMDfPqB9uZcBVA.izeR67tNnP2P7iOp0b9hrn0kFtRUsLJecbvCutRivChVBcazsQ5ox.GWFc4RgBIClSPbmEyQAtNTz7PmP0RJkRvtCzwsVDljGNKJtVI0OXuVWEDEW8ozrn6hRBhuzyr+2FHhXAXBYTkP1x2EZ98gQ2cOzaDrBnTUwXeEwkhgVlG7gvK8no39MqlmraRuIq9CeHLYYEpCBkD9ohWmtL7mVBiZvyHA9btV83RBRQQVz7MEUOZdTAvJzi5OOn3g05gUTBvZ.XBzZP7lPcOWRutOcYmRA8jMYHO1z.hBlW9wlM413zfB59V76Zi4Ps48csaaWcEts3YgZ25OXuqFRzcR0+11j.DZd5ljk4Mo.JZCB..aeZvqDJfvnoNXWnIKhCxKaQzRsKfiDX7RAZlmOEw8m3iTdJBx00S3nDT9XJuI4fTpgzEuGZ6G.mozA0I.nmIvOx.Lt7QI4EAIEUf6Cqq6x54x7zz38SjaChyCebWBGGXY3MrL.BLDOxUxcvBkhyERIiKnU1q5zPrzbnwCqMt4EgqysYcoZq68QKgvEPK2NE11vio.lQYyzrg6o66Xz03cM28c6bN+qYAKizoA0vo6+7gn7n45fQEYazVNxWtC0soIEMjIGzAjI0NQFLNKJHV6MGUBnKBy+t2wJu3g3Pay42Dd2l3frAlcvHB9I8vHm1+xm56g3yHSPtXxXjm+LOtCeJyC67T8u1mqbGPSOcDqxVxhA5sPjcMmXeB8GX0azsUKBsBRAnjIY08jry8rLM8SqzG2mzuE7FODHUsbiKY6aY.M4zC26guandwbx26MqMb27FXQxRjwhCsgkHgo2GaOa+XCHIGn.UNp2GjWlXZWnbobQImTt5gRu86aqqCPLMGHsLurbzBvkpnKW6MIQcJCP8pyp4zR04Zj5bvAiEtz+k6xNsG7TJSf3ikiQSjRBBSGOwWH7bnyl0zCl8E3AenG2Q78Vr3lz1ZZvVvrBF1SBNzpuynUag2SM+0RWNqjRCKyzS1gQTPnNJNJQ4JG4vTbLiQwLhtJU.VniDRFk6RfebDBlCwRfVuIJoFllgFOdxXDF65w8TSlH7HesRj49fjjv3tnuGB5EPvgMYgzk6ESWuTojvvtny9srfst0m4Dap6i8i9lt96oI+cceXkkPurrjV9pzRVBTXFSyRDTAyEKqIIjZRBi6Jb4DhjZgjLw2eLBV8UgT99BD1exXt2jo3w99OURReg0S3R2dwBng27Ka5H6O1W9hE8N59YE79xGXV3HNMXx8b8gTqb.XkOCiDbhXhCg4OlLoIXRuTAl6YIIcEy9DQlaP.RWeiW4.zJ7y+wG9kBmWlv+tRJexf8jzhhzU8AuE+3i2JKogMi5NCwE9tnwJFCQI9vJ7NB7jwNWZ39nBe9aoe7lkog42TbeT9Mwoou+uL3hA8kUUYE4kWqy+ERc9Bw0J8uVo+knRemi8o06PeZF5fM.td+A2hL01fGGdFA+AvtCstOY0yJTPZQ4gU0mg7fsfdumeMNMrd1ldWtIkiGo3BghfEboxopRBItpTBGoBKkbcEFm1a2kRgTPfpLQtSoSQhYJWkuK2yiwdpKGUwC5j2eNURtEoruSMFcJMcDEMNmxyy6rhi1zqrA6z.jeHGqEGZXKOlFSxsyjsBzz+T2C2llsxt2o5YOWq9xUoRVI4zgY4Pb7c7gbib4bjZlGEMUggxawbFyaxEorVrcdS8gKaQldwBvMvoYaISV.I2Wbfjx1dO7mRPh9ieQKjWl0r7VcoJvuA2.18hQCtL6KQmEqPeFOBi5t3heBFs5RCYhZ8HNPjuONiCqKf7s6LNvin3pentJLkQo7mvodbdm8glP+usylIWYyuvXyHxHQ2K19siPi9Vxnq2RoNH0zq0d9Rq1ShPds3yqEeV5d9DNWO8U6UG3.sLZUXRd0KXgcGocMo299kMHJ4r6injd2GU.S+6f9DmYu1yee3GOCkWJdOCyTc6vOCkW2fdGXJ8LM80M3IDDyvMK0kPFQfPXJliZ+Iw6vbFwYRGoivQQrF+xEhZww5RgoS8fEq8wSY3oybTO4igeKctGQR1xJsIJhLDQLEt6TgE0jEaY6J1g48IVWZWiOKg4ZDZ6H2oCcIM6UeXvAywWZywLQQayxM4jzzI6X+yFP09gPsbstiJqsGX83SPsuqZijxQJJEVs10QJ1R3QBmQJIkS6lwGtPxQb9sNn4btDsLjFfoT7BwbUSFO97Y7s.+RKArxS95vEv5YvBRUGSwzCNlh+g9R8eyOkbapcKl7or8M5cK5bigieJQpXXCQpvijRAU07dkgDpQbMtPvbGFj0kcriPckH.j4nwR.6Dd9LnXBpKUIed13t96fia4g2xZuGrec3cAE1uieT0SDnOiU1uv67JcjqCgiEP0V.NsMe5RHVw3RGBlB+yNbOmNgSQbG+oHW7zInwddT5zwLeOF8Y4tj7zxTswasUMD+OSVGrv9Ezi9xY6xEJ4H86fEg1H6gyzo7Ok6lN6a+0Ce+UH34X24+ZuYRzphukhWjW+a8Mqn+6bz4e2u+4njva9sRKhUVG9ZAoWKH86vBRUD2qEjdsfzWrEjxnesKuhbNQYh9iP6uprUu7p3dt095+GoWx1WudhvAOxEKXth5L7qesgbgZqktDJ2Uwc3DaGTzX2wPdjdS3nID7LDCJgXBSNYhjc4yiz1a5yAoS1q2djZxQIPsEKLwL1Z6MQB1yVGuboU1J+61jOwn3f4sdwrN51R7yg2Vtb41FT+b6YhVILoas6EBMOaPilzo92O5ocq+2T5hznEcpd54jYN6aVl4TtkW.Dpj6h3AymilyT2h3gDLVPfh9IhKcQ6lK18xkXdad5gzvCYZGRiNjobHO3nD+Gu69jayg24Z0lOGbZF8k4Ew4YsTyes5x7ey+xJiSckwcYYbauqLbxKx6JyWGNm8aCy2nsE0P5rauEwVCP7c99ddFa2Y8K.1lrEaOptMQ5NdAz9rxurwzGLmB6LRIbYDHycthy1t++tXr94stmM+Qp9K9L7HsTNXJgScHBtfWVsSXb02Hk5gMUm.gdrUlIg9N0neMln5ipS+ECl9x6p+r1BpyplnOGHp9+PzOhp+ShtUDsjTshJOGARovZUQJ+SsNnksnTXsBnZQX5uS2d7+Of6B1N
--end-wire-patch--
rawdesigns
Re: Text color
OMG this is amazing! thank you so much! I wish i knew how to use Wire
