Pioneer bridge sync problem
VisualLabRick
Post by VisualLabRick »
I’ve been trying to setup pioneer bridge and am having some trouble..
I do see all the cdjs and mixer in green and also see them in resolume, even displaying the track and if it’s playing or not.
But when I link it to a video it won’t play.. it sticks at 00:00
It does trigger the clip and the fader is also working, it’s just not playing.
The file name is the same and no firewall is running.
I tried the exact same composition on a Mac and it works. But I want it to work on my windows 10 laptop.
Any suggestion what the problem might be?
Re: Pioneer bridge sync problem
Both Resolume and Bridge app running on the same machine?
VisualLabRick
Zoltán wrote: Tue May 16, 2023 14:21 Both Resolume and Bridge app running on the same machine?
Yes, running on the same laptop and having the latest version of resolume and bridge app
VisualLabRick
Oke so we didnt get the windows laptop to work.
Now for the mac, everything works except we have one problem: everytime the DJ loads in a track on the cdj, resolume freezes for a couple of seconds.
While the laptop we are using is a new M1 Macbook Pro
(see attachement for specs)
Any idea what can cause this problem?
Are all your videos DXV clips?
VisualLabRick
Zoltán wrote: Wed Jun 28, 2023 10:58 Are all your videos DXV clips?
Yes all DXV 3 normal quality
Internal SSD?
Maybe the drive is going to sleep?
VisualLabRick
Yes internal SSD, and its not going to sleep.
EBMCreative
Post by EBMCreative »
I have this exact problem on a windows machine.
Does anyone have any ideas as to why the time counters do not work?
Which Resolume and Bridge versions?
