Performance Problems
uge
Post by uge »
Hello there,
I've just updated to Resolume Avenue 7 and Wire. Coming from Avenue 4 and Quartz Composer. Also I've updated my computer from an iMac (Mid 2011) with El Capitán, to a Macbook Pro 2019 with an i9 processor, 32GB and Ventura (2 graphics cards Intel UHD 630 and Radeon Pro 560x).
In my previous setup, I had no problems working with Avenue and Ableton in the same computer, even using lot of QC clips. My setup now slows down a lot, and the system starts to blow just at opening Avenue with 2 or 3 clips loaded. If I open Ableton the things start to be really slow, and the GPU in Avenue reach almost 100%. I can't open Wire because everything goes blocked.
I'm not sure if there is something that I'm missing. Any advice will be appreciated.
Thanks in advance!
Re: Performance Problems
What kind of files are you loading into Resolume?
