Resolume Arena mapping led strip WS2812 problem,plaese help
gmax85
Post by gmax85 »
Hello,I'm new member,I have controller K16000s and led strip ws2812 144 led/m and i've conected 16 led strips with diferent sizes to the controler,so i need to controll each size through conected controler channel. When i go to Advanced section to do the mapping,i can't get other channels to work,just the first channel,for example,if I add Lumiverse 1 and coresponding fixture 170px add to Lumiverse 1,height 1,first meter of the strip lights properly,but if i need to "activate" second strip on channel two of the controler,nothing hapens,but if i conect 1m of led strip to strip conected on a first channel(so first channel have 2m led strip conected),it light up properly,but as I said,nothing on the channel 2 of the controler.
So,when I setup first Lumiverse 1 on the first channel of the controler,then creating Lumiverse , how I can "tell" the controler that signal should not go to the first channel,but the second,because he adds pixels to the first channel,not the second,as i want it?
Big thanks,Goran.
Re: Resolume Arena mapping led strip WS2812 problem,plaese help
If you changed the target universe and subnet in the Advanced Screen setup on the Lumiverse,
https://resolume.com/support/en/dmx#usi ... lumiverses
then check your pixel controller's manual on how to set that universe to be the input for your pixels.
