nOB Controller with Resolume?
jakemelon
Post by jakemelon »
This knob controller looks very intriguing to me because I'd like to use it to control the playhead in Resolume effectively "scratching" video like a record.
https://www.nobcontrol.com/
Does anyone know if it works with Resolume? I can't even tell if it is a midi device on their website.
It is a bit expensive to try and find out it doesn't work... Hoping someone already tried it.
Is anyone using it with Resolume?
J
Re: nOB Controller with Resolume?
With up to 2400 counts per rotation, nOb delivers precise adjustment even in the most demanding fine-tuning situations.
2400 positions for a clip timeline is not that much.
I'd look for something which can send out OSC, floats will give you much better resolution that this, or Midi.
jakemelon
Post by jakemelon »
thank you Zoltan.
