plugins not working
PLAMPvisuals
plugins not working
Post by PLAMPvisuals »
hi there, I could use some help i have read countless posts on the forum about this and have tried everything to no avail. i have several plugins that will not show up the resolume effects tab, I have tried to re download them and make separate folders for them linking resolume to said folders in the preferences video tab and nothing is working. the plugin I really want to work is the MASTERFX plugin. the demo for this plugin worked just fine so i do not understand what the problem could be. the log showed at some point that they failed to load but than upon closing resolume and reopening it the log doesn't show the effect at all. please help.
Re: plugins not working
Try uninstalling, and reinstalling the plugin, maybe it needs an update which Juicebar can't do for some reason.
Make sure Resolume is closed when you do that.
Also, if you move the Juicebar plugins out of the Juicebar data folder, they might show watermarks.
phattyj
Post by phattyj »
I am also having trouble with 3rd party plugins showing in resolume. I put them in the extra effects folder and also tried to load them through the video preferences as instructed in the support page, but they still don't show under the effects. I don't understand how you would uninstall a custom plugin because it's a .dll file.
any help would be much appreciated :)
J
Old FFGL plugins on recent Resolume?
