Hi all,
Got a puzzle for you. I have an opera that's opening tonight. A few of our clips, seemingly at random, are playing back at double speed. For example, I've attached the project file and one of the clips that is behaving like this. It was converted from mp4 to DXV in Alley. It's 30fps, and should have a duration of 13.36667s. Resolume agrees. When I click on the handle to preview it, it previews just fine, but when I actually trigger it, it completes in 6.68 seconds. Baffling.
Attachments too big, use this:
https://www.dropbox.com/t/TBcCv0zoZ9L12XPA
The hardware running the show is a PC, Intel i9 chip and nvidia 3060ti, but I also loaded the show on my M1 Macbook Pro and can replicate the problem exactly.
Occurs with or without output enabled.
Solution we found is just making all clips that exhibit this behavior at .5 speed. Not a big deal. But still...
So... what's going on? Any ideas?
Thank you!
Some clips playing at double speed? Why?
Full Spectrum
Re: Some clips playing at double speed? Why?
Some more Questions to hunt this down:
What is the playmode set to?
Is there anything different in the clips like do they have audio (also a silent one)
Are the "fast" clips all in the same layer and the others in a different? -> Check layer properties
I guess we soon will get it =)
~Berlin~
~Berlin~
Full Spectrum
Just replying to this to confirm that yes, I'm an idiot.
Either I or the operator must have used the scroll wheel flippantly which caused the speed slider for one of the layers to increase.
100% my bad.
However, if I could shirk responsibility, I would love to be able to disable the scroll wheel from altering playback settings. It's dangerous when handing off a show to an operator who really just pushes buttons per my instructions.
Thank you!
100% my bad.
Thank you!
