Resolume uses Aja cards exclusively
elgarf
Post by elgarf »
Tried to use vMix with Arena on same pc (vMix as video mixer, and Arena as display software through virtual web camera). But Arena blocking using my Aja Corvid 88 in vMix.
I think it's because of advanced output.
Can there be option to not use some capture cards in Arena?
Re: Resolume uses Aja cards exclusively
If the AJA card isn't in use in Arena (input or output), there shouldn't be anything preventing other apps from using it. What happens if you open the other apps first?
elgarf
Post by elgarf »
I've tried opening vMix first.
I enabled output through aja's sdi 8 port, and saw multiviewer on external monitor. When I opened Arena, image on display disappeared.
Also I don't see any aja inputs in vMix, when Arena is opened.
That's odd.
@Zoltan, would this be a bug? Sounds like one to me.
Could also be capture clip left somewhere in the composition.
Does it also happen with a new empty composition, and new advanced output preset?
elgarf
Post by elgarf »
Can try it a bit later, but there wasn't any clips with this capture card and outputs through advanced output, that using aja.
elgarf
Post by elgarf »
Hmm. Tested now, and all is ok, even if card used in arena :? maybe windows bug
